Pin reset of HSC08
Pin reset of HSC08
PinresetofHCS08
hello,
It is possible to desable the pin reset\ of the HCS08 by desable a bit of any register, because this pin is very sensitive and even if a make a capacitor to the ground, many times the software reset. I'm sure it's this reset because i displayed the reset status register on an LCD.
PinresetofHCS08
I'm using MC9S08GT32A MCUs
celsoken
Contributor V
So you have a dedicated Reset pin, have you placed an external pullup resistor to VDD to enhance EMC susceptibility? FS suggests 4K7.
Cheers,
Celso
celsoken
Contributor V
You have to tell us what specific microcontroller you are using, most uC do have an option of turning reset into an input port.
I suggest you also investigate why the part is reset. Maybe you have EMC problems to solve before.
Cheers,
Celso
