How to correctly configure Route Record Table
Question asked by tianheng han on Jul 27, 2020
Latest reply on Jul 30, 2020 by Mario Ignacio Castaneda Lopez
      We are trying to increase the number of devices that can be added under ZigBee network, but we have
encountered some problems.
      First question: regarding the use of ‘Many to one’, we hope to increase the stability of the network by using ‘Many
to one request’. When sending the request of 'Many to one', how often can the best effect be achieved.Is there any
other way to send ‘Many to one request’ besides using  'ZPS_eAplZdoManyToOneRouteRequest' to send requests
actively?
      The second problem, I saw in 3113 that if Coordinator uses' Many to one ', then it will replace  ‘Routing table’  with
Route Record table’. However, during the test, I found that when Coordinator uses' Many to one', the setting of Route
Record table to 5 can also work normally. Should I use 'Route Record table' instead of "Routing table"?
      Third, when i set 'Route Record table' to 30, I found that the device could not work normally, If i need to set 'Route
Record table',how much should i set?
      The coordinator is use JN-1216 JN5169,Here is my configuration diagram.
      Thank you very much.
      Coordinator configuration information
