yu xidi
MC56F803x_trim.asm gets lots of bugs ?
Discussion created by yu xidi on May 11, 2009
Latest reply on May 20, 2009 by Pascal Irrle
Hi guys:
      I used wizard to produce several files for project for MC56F8036 which includes a file called MC56F803x_trim.asm. although I do not need this file, I also studied it carefull and found several points I think they may be bugs. the file is presented as follows:
; sample code
; 01x freq trim code
CLKGEN      EQU $00F0F0
OSCTL       EQU $00F0F5 ; CLKGEN + 5  ; osc control register
FM_BASE     EQU $00F400
FMOPT1      EQU $00F41B ; FM_BASE + 1B  Reserved for trim cap setting
                        ; of the relaxation oscillator
                        ; (on chips other than 56835/836/837/838)
 section utility
 org p:
 GLOBAL F__trim
 SUBROUTINE "F__trim",F__trim,F__trimEND-F__trim
F__trim:
; get trim value and set trim reg
 move.l   #OSCTL,R1    ; set R1 and R0 to OSCTL
 move.l   #OSCTL,R0
 move.w   X:smileysad:R0),A     ; set A to current OSCT value
 move.w   #-1024,B     ; set B to mask
 and.w    A,B          ; mask A
 move.l   #FMOPT1,R0   ; set R0 to factory-flashed trim value
 or.w     B,A          ; or A and B to get full OSCTL value
 move.w   A1,X:smileysad:R1)    ; set OSCTL
 rts
F__trimEND:
 endsec
 end
also I modified them as :
; sample code
; Substituted with the follows by Xidi on 05.11.2009
;CLKGEN      EQU $00F0F0
;OSCTL       EQU $00F0F5 ; CLKGEN + 5  ; osc control register
; removal end
CLKGEN      EQU $00F130
OSCTL       EQU $00F135 ; CLKGEN + 5  ; osc control register
;end of modification on 05.11.2009
FM_BASE     EQU $00F400
 section utility
 org p:
 GLOBAL F__trim
F__trim:
 move.l   #OSCTL,R0
 and.w    A,B          ; mask A
 rts
F__trimEND:
 endsec
 end
 I don't understand whether the orignal it has been tested or not.
