Hi guys,
I have to set my display resolution with hdmi is 800x600, but i have no idea about some of paramters(hsync start, vsync start). So, I need to calculate these parameter to set up hdmi display for 800x600.
Do you have any reference to help to get values or docs or link?
these parameters are depends on your display, you can refer to the display data sheet, which should include these parameters
