Hi.
I consider using TDA19988 to design HDMI transmitter circuit.
I wonder thd default setting of input port for RGB888.
Datasheet confuses me.
It is important to let you know that the TDA19988 is now marked as “End of Life” in our system and unfortunately, it was the latest HDMI transmitter from our portfolio. So, there are no replacement for this device in the current NXP portfolio.
For the TDA19988, market is no more here and there is no more support bandwidth allocated, so we target only big opportunity by direct contact through our sales.
I’m afraid that if you need any support for this device you would need to contact your NXP Sales Representative.
I apologize for the problems this may cause.
Jose
