How to add processor expert for Existing project
459021854
how to add processor expert to Existing project which did not import when created?
I want to add some component to Existing  project without create from scratch.
thanks.
jiri_kral
Processor Expert is part of SDK, you need to add SDK in your project:
Other way is started new project and add SDK in project wizard:
Hope ti helps.
Jiri
jiri_kral
Hope ti helps.
Jiri
ErichStyger
Senior Contributor V
See section "Adding Processor Expert to the Project" in DIY Free Toolchain for Kinetis: Part 8 – Processor Expert, Eclipse and GNU ARM Eclipse Plugins | MCU...
I hope this helps,
Erich
459021854
Hi erich,
but In S32DS for arm2.2 menu File > New > Other , there is no such choice,
