LPC54628: Using LPCScrypt program loads but does't run
Question asked by jbhoi@slscorp.com on Jul 14, 2020
Latest reply on Jul 19, 2020 by Alice_Yang
I am using LPCScrypt to flash the firmware into the LPC54628 board. Program (bootloader and application) loads successfully but doesn't run. So I have checked the memory content of flash using memDisplay command and found that memory content remains the same as the bootloader has after flashing the application image. see below snapshot.
Any idea what wrong with it?
Also, the erase command failed to erase the flash. Using memDisplay i can see flash is partially erased. see the below image.
why erase failed?
