Hello, Could you help to solve the problem that my customer met,
My customer used S32K144 as the MCU platform,but they use inca software fixed the RAM map the Flash,but after the step, the Flash neither read nor write,I dont know ,what is wrong ,
other projects ,i used inca software to fix SPC5744 ,All things is OK, I doubt the Inca is not use for theS32K? so what software can be used for fix S32K144
