Lpuart and Gpio Drivers Error (MKW36Z512VHT4)
va_ita
Good morning,
i have a problem with Drivers of LPUART and GPIO of MKW36z512vht4 Project write in C.
SDK (2.2.5) drivers and project drivers created by MCUXPRESSO cannot be aligned.
I believe that the different versions of the drivers lead to the errors reported in photos.
I would ask you kindly to give me an explanation as I cannot properly fill out the project.
I thank you for your reply.
Alexis_A
Hello Vanny,
Unfortunately, the KW36 LPUART and GPIO are not supported yet by the config tools. If you look at the problems tab in the IDE these messages appear:
I will suggest using the example codes for the LPUART and GPIO to know how to set the module.
Alexis Andalon
va_ita
Hello Alexis,
thanks a lot and I hope that, as soon as possible, they can make compatible the configuration tool also for kw36.
For now, I’ll try as you suggested.
Best reguards
Vanny Cecchinato
