In the bootloader application, why we choose the SREC format to send data.
It is up to you if you use SREC or other file formats. A bin or hex file can also be used.
Diana
I would like to add a note.
If you are building your own bootloader you can choose the file which you want.
However, our example such as AN12218 is programmed to process SREC. So, if you want to use another format you should change the code.
Diana
