I plan to create a few data variables in ITCM (RAM Partition 2) to run a few memory tests on a MKV58F1M0VLQ24 MCU. Do I have to configure register(s) to enable ITCM? If yes then which register(s)?
Solved! Go to Solution.
Hi lsrbigfoot
If you want to create a few data variables in ITCM, you just need to define the data in the related ITCM data range:
You don't need to configure any other register.
You can try it on your side.
If you still have questions about it, please kindly let me know.
Kerry
Hi lsrbigfoot
Kerry
I tried accessing ITCM to do a few memory tests. Memory appears to be working. Thanks!
