k66 RESET_b is pulled down by chip
1043064987
I use Jlink commander "unlock kinetis" but it time out.
There's only one 4.7k pull up resistor on RESET_b but it always at 30mV.
myke_predko
Senior Contributor III
Hiya,
How are you connecting the other JTAG pins?
A couple of notes:
myke
1043064987
Hi Myke,
Thanks for your notes. But when TMS is open, TMS is 3.3V. And after EZ_CS_b is left open, the RESET_b changes to 0.2V.(no longer 30mV)
myke_predko
Hiya,
Can\ you put in a drawing of your programming circuit and the different signal levels?
Attached is the circuit I use for programming to the Segger JLink Plus (should be the same connections as you use) and the Segger Needle connector:
Just a couple of notes:
  • /UC_RST is pulled up and has a voltage supervisor on it.
  • EZP_CS_b is left floating
myke
1043064987
   Thank you. Finally, I solder a new one and it's all right. Maybe when I soldered the last one, temperature was so high and burn the chip.
myke_predko
Good news - keep us updated as to your ptogress!
