Liping Zheng
View variables in expression window
Discussion created by Liping Zheng on May 6, 2009
Latest reply on May 7, 2009 by Mike Fugere
I'm using Codewarrior 8.2 for DSP56xxx. Can anyone tell me how to view variables with absolute address in Expression window? For example, if I want to view the int value of a variable located in X:$8000, what kind of expression should I write in Expression window? And also, how to update the Expression window (automatically or manually) while the code is running? Thank you.
Sincerely yours,
Liping
