L4.14.98_2.3.0 with i.MX8X
m_c
Senior Contributor I
In the release note of L4.14.98 2.3.0, it said supports i.MX 8QuadXPlus C0 chip.
May we know how to check the i.MX8X chip is C0 or not? By part number?
joanxie
To distinguish between i.MX 8X B0 and i.MX8X C0 parts, users can check the
last letter of the part number, which indicates the silicon reversion. For
example, MiMX8QX6AVLFZAB indicates that it is i.MX 8X B0 part, while
MiMX8QX6AVLFZAC indicating that it is i.MX 8X C0 part.
joanxie
yocto building is based on board, you can find board revision B0 or C0 on your imx8qxp board.
m_c
Thank you for your reply,
If customer build their own board.
How to make sure the i.MX8X IC is C0?
joanxie
