K32W baud rate
K32W baud rate
danieltseng
Contributor V
1. Update with "DK6 Production Flash Programmer".
    I know that when using LPC-Link2 USB connection can not reach 1M baud rate, what is the default speed?
    What is  the  highest speed that can be set in LPC-Link2?
2. If the SOC uses UART0 to connect to K32W,
    Can K32W receive 1M baud rate?
    Does RTS/CTS need to be connected?
  • KW
danieltseng
Contributor V
I tried using "default baud rate"  and  "-P 115200", but it took about the same time for download.
"which speed are you referring  to"   on LPC-Link2 ?
estephania_mart
Could you please try setting the verbosity in a higher level so we can verify about the boudrate ?
Estephania
estephania_mart
Do you mean with the SWD programming ? Or which speed are you referring  to ?
The questions 2 was already solved in https://community.nxp.com/thread/535671
Estephania
