MPC5748G : Flexray Shadow RAM and FIFO difference
Deepak1
I am reading Reference Manual of MPC5748G microcontroller.
I want to know what is the difference between shadow RAM message buffer configuration and FIFO message buffer configuration.
As both configurations are used only for receive frames.
Thanks !
petervlna
Please see following:
best regards,
Peter
Deepak1
This is the information about how the received data is copied to shadow buffer.
But my question is what the difference between shadow and FIFO ?
As both are used for receiving data. Then when to use shadow buffer and when FIFO for receiving data ?
petervlna
As described above.
Receive Shadow buffer is used for receiving data (which age going to be validated)
Once data are validated the are going into FIFO receive MB.
Always when you want to receive data.
regards,
Peter
Deepak1
I am referring MPC5748G Reference Manual, Rev. 7.1, 01/2019 and FlexRay specification document.
Other than this any other documents or application notes or manuals are availabe which can be helpful for implementing FlexRay driver using NXP microcontroller ?
I am using DEVKIT-MPC5748G development board.
Thanks for all the imformation that you provided it will be much helpful for me during implementation.
