USB download error
USB download error
chenyuqiwei
Hi,everyone!
I ran into some problems. When I downloaded the image from USB to imx6ull with mfgtool2 tool, there was an error in downloading. It shows where the card is loading the kernel. Does anyone have this problem? How did it work out? Thanks!
Rita_Wang
Could you tell us which version of BSP are you using?
chenyuqiwei
Rita_Wang
Are you using the reference board or the board you design yourself? The mfgtool use you can see our user guide 4.2 Manufacturing Tool. Here do you configure right files for you board? Or you can send your log file to us.
chenyuqiwei
Hello,Friends!
      I will try it again,Thanks!
