Debugging with no flash
mspenard603
Hi All,
 How do I properly debug with MCUxpresso and a J-Link on a iMXRT1062 without flashing first?  I've unchecked "Load Image". But when I click Debug, and then Restart, I don't ever hit any breakpoint I set in startup_mimxrt1062.c's init code. My Jlink must not be syncing even though it's attached or something...?
FelipeGarcia
Hello Mike,
I recommend you to check this blog from a colleague Attaching to a Running Target with Segger J-Link, GDB and Eclipse | MCU on Eclipse
I hope this helps!
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored.
