In S32DS DEBUG "hello_world" Example, Example run away.
wuyongren
In S32DS DEBUG "hello_world" Example, Example run away.  What should I do?
Tags (3)
wuyongren
Thank you very much. I've solved the problem. It's the clock problem.
jiri_kral
I tried your scenario - S32K144 EVB, J-Link Lite debugger and Flash target - and no issues on my side. What's your J-Link gdb server and S32DS Version?
Mine is GDB Server V6.42a and S32DS for ARM v2.2
Jiri
wuyongren
18062294269
hi
   I also ran into some problem with the examples.Could you please leave me a contact information?
