Is it possible to reduce power consumption by disabling the CPU Core?
Question asked by gyosun shim on Jun 16, 2020
Latest reply on Jun 16, 2020 by gyosun shim
I am using LSDK18.03-k4.9 for LS1043A.
This is a situation where a lot of heat is generated due to the system used without the FAN, so the power consumption must be reduced.
How can I disable power consumption if I can reduce it?
Desperately waiting for an answer.
Thank you,
Best regards.
Gyosun.
