Good morning,
I'm working with an LPC845 series and I discovered that, on the same microcontroller, if I read serial number with ISP interface I get a value but if I read the same by SWD interface I obtain an other value, only the signature is equal in both cases. Serial number is stored on a database and I read this value to generate a key for firmware update.
Why this behaviour?
Thank you.
Have a nice day.
Pasquale Barrega.
Hi Pascual,
Sorry for the delay,
I am assuming that you are trying to reading the UID (which is 128 bit wide).
I would take as valid the UID returned by the ISP/IAP commands. However, I am not fully aware of your procedure for reading the numbers using SWD.
It may be possible that the SWD is pointing different to a different memory location.
Could you provide a screenshot or the serial numbers you are reading ?
Diego.
Hi Diego,
attached to this e-mail you can view two screenshots that show the Unique ID number read by ISP command and by SWD tool, precisely LPC-Link2.
To read this value I used the software Flash magic with it’s gui.
Best Regards.
Pasquale Barrega
Da: diego.charles <admin@community.nxp.com>
Inviato: mercoledì 17 giugno 2020 01:53
A: Barrega Pasquale <P.Barrega@duplomatic.com>
Oggetto: Re: - Re: LPC845 serial number
NXP Community <https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
reply from Diego Charles<https://community.nxp.com/people/diego.charles?et=watches.email.thread> in LPC Microcontrollers - View the full discussion<https://community.nxp.com/message/1327613?commentID=1327613&et=watches.email.thread#comment-1327613>
Hi Pascual,
Thank you for your reply,
I suggest you to check the iap_basic example on the SDK . It will help us to determine which number is valid.
Please, let me know your results.
Diego.
