NTAG5 with KW41Z FW example
ethanchen
I check below document description about NTAG 5 - Firmware development for KW41Z
https://www.nxp.com/docs/en/reference-manual/RM00222.pdf
Where can get this FW for reference? Thanks
pavel_meld
Looks like this project is attached to this topic here. See right above comments section.
estephania_mart
The firmware mentioned there is not available yet, only the snippets of code there in the chapter 5,  once  the software is ready to be uploaded, it  ready it will be placed in the web page.
Sorry for the inconveniences this might cause you, I can post here and let you know once this is done, would this be ok ?
Estephania
ethanchen
Hi Sir,
   Have any update about this?
   Thank you.
Ethan Chen
estephania_mart
I'm still checking for a date , sorry for the inconveniences.
Regards.,
Estephania
estephania_mart
Sorry for the inconveniences this might cause you but we do not have an estimated date for this,
Maybe you can check this other NTAG 5 C library SW release to use as a reference
https://www.nxp.com/webapp/sps/download/license.jsp?colCode=SW6090
Regards ,
Estephania
ethanchen
Hi Estephania,
OK, please inform me, if it is available.
Have you time slot on this?
Thank you.
Ethan Chen
