SDK required although I installed the latest version of SDK
abderrahimjamao
Hello, I have a problem when I try to install an existing project.
dianabatrlova
The MTRDEVKSBNK144 example code is built on an older SDK EAR 0.8.6 which is not supported by the new S32DS for AMR v 2.2. Because between the SDK versions are differences the easiest way will be to use the S32DS for ARM v 2018.R1. It is possible to import and run this example code to the S32DS for ARM v 2018.R1 with a few changes in the properties. S32 Design Studio IDE for Arm® based MCUs | NXP
This question have been discussed here:
https://community.nxp.com/message/1278208
I hope it helps.
Diana
abderrahimjamao
ok, thank you so much.
dianabatrlova
If you will have any difficulties with importing MTRDEVKSBNK144 to S32DS ARM v 2018.R1, please, let me know.
Diana
abderrahimjamao
Thank you very much I managed to import the project but I have an error when I debug the project.debug.PNG
dianabatrlova
What happens when you click the "Retry" button?
Are you able to build the project without any error?
May I see your debug configuration?
For example, I'm using OpenSDA so my settings see below:
Diana
abderrahimjamao
thankyou, it was a bad contact between the shield and the board.
