BSDL for MCIMX6Z0DVM09AB
csubda
Hi Support,
I need help with getting BSDL file for MCIMX6Z0DVM09AB to create Boundary Scan tests.
Where I can download it ? Product page does not to refer to anything. Also generic NXP page to search models (Microcontroller Symbols, Footprints and Models | NXP ) does not help.
Pls post it for download!
Tags (2)
csubda
There is a link for UltraLIte (UL) BSDL files, but I'm not sure, if it is the same as for Ultra Low Cost (ULZ)
nxp.com/webapp/sps/download/license.jsp?colCode=IMX6_UL_BSDL&appType=file2&DOWNLOAD_ID=null
NXP Support, can you help me ?
Rita_Wang
This is for i.MX6UL not the i.MX6ULZ, For the BSDL file for i.MX6ULZ I share it to you and send it to your email. Please have a check.
csubda
Thank you for confirmation. Downloaded via NXP case portal.
Thx a lot!
Rita_Wang
Yes, I send it there.
csubda
Hi Rita,
Initial verification by BSDL syntax checker and fitting with customer's netlist pin names passes without errors :smileyhappy:. But pls note final test will be in few weeks, when board will be tested. It will show finally how suitable is this file working on real hardware...
Rita_Wang
csubda@wg.com.pl is this your email?
