FreeMASTER Oscilloscope recording error
623619261
The function is all right except the data captrue.
I can't save the file.
MichalH
NXP Apps Support
NXP Apps Support
constantinrazva
Hello 623619261@qq.com ,
Can you share the FreeMASTER project?
I'd also like to know if you are using our Simulink toolbox - if not, then I would suggest you post your question on the FreeMASTER community - there you'll certainty get the help you need for this.
Kind regards,
Razvan.
623619261
Thank for your reply,I just use FreeMASTER.
The project is very simple and just set a variable and Oscilloscope.
I want to try this tool for a new test method.
I will post this question.
MichalH
NXP Apps Support
NXP Apps Support
This discussion continues at https://community.nxp.com/thread/533939
constantinrazva
Thank you MichalH for this link-- can be helpful for other users with similar issues.
Kind regards,
Razvan.
