Which heat sink can be used with the IMX8M Mini?
vadimaleynikov
Which heat sink can be used with the IMX8M Mini on the 8MMINILPD4-CPU board?
Tags (2)
gusarambula
Hello Vadim Aleynikov,
There is not a document specific to the i.MX8M Mini and Nano, but Application Note 4871 (link below) provides the general recommendations for BGA packages.
https://www.nxp.com/docs/en/application-note/AN4871.pdf
I hope this helps!
