IDE 11.1.1 SDK examples fail - fsl_common.h not found
Question asked by Torbjörn Johansson on May 28, 2020
Latest reply on Jun 1, 2020 by ZhangJennie
I've just upgraded to MCUXpresso IDE 11.1.1 and important an SDK example to get started. When building it the compiler complains that the file fsl_common.h is not found. But that file is included with the example and its path is on the build path. This was example i2s_dma_transfer. I also imported the RTC example and got he same error.
What could be wrong? I haven't changed any settings in the SDK examples, just imported and then built.
Kind regards
Torbjorn, Sweden
