MIMXRT1060-EVK examples basic peripherals
e_v_spronsen
I'm getting started with the MIMXRT1060-EVK. I installed mcuxpresso IDE and SDK. Only what I didn't find are basic examples and documentation how to use the basic peripherals. Like Timers, GPIO SPI, Can  etc.
Where can I find this.
Thanks!
victorjimenez
Hello Ernst,
When downloading the SDK from Welcome | MCUXpresso SDK Builder you will see the following window:
You need to click on Download SDK Documentation. Within the zip file, you will find a pdf named MCUXpresso SDK API Reference Manual_MIMXRT1062.pdf, this is the file that you are looking for.
Victor
victorjimenez
Hello Ernst,
Within the SDK that you downloaded, you will find example projects along with drivers that demonstrate how to use all the peripherals of the RT1060-EVK. I recommend you watch the following video: MCUXpresso IDE - Importing SDK | NXP.
Regarding the documentation, you can download the RT1060 Reference Manual from the following link.
Victor
- If this post answers your question, please click the "Mark Correct"button. Thank you!
e_v_spronsen
Hi Victor.
Thanks for the info. I found the examples in the SDK.  For the documentation I'm searching for the Driver API documentation. The driver code itself is very very limited documented. So understanding what a function supposed to do or what the parameter mean is not always clean.
Evs
victorjimenez
Hello Ernst,
Victor
