About - SL3S1003FUD
Question asked by 烨 李 on May 22, 2020
Latest reply on May 27, 2020 by Kan_Li
关于这个芯片-SL3S1003FUD,是否可以设计成用继电器短接或断开OUT-VDD,开启或者关闭芯片射频功能?
如果不行的话,请问有哪个型号的RFID芯片可以实现这个功能?在900M频段的。
谢谢各位。
Regarding this chip-SL3S1003FUD, can it be designed to short-circuit or disconnect OUT-VDD with a relay to turn on or off the chip's radio frequency function?
If not, which model of RFID chip can achieve this function? In the 900M band.
Thank you all.
