i.MX8 SATA port multiplier support
dirk_rossow
does the i.MX8 Family (QuadPlus/QuadMax) support SATA port multipliers and which type (command based or FIS)?
Where do i find a public available reference manual?
Thanks and kind regards
Dirk
Rita_Wang
We didn't do corresponding test. But got answer from BSP design team: SATA port on i.MX8M is ahci standard, so it should support SATA multiplexer.
I only found these https://community.nxp.com/message/1178390?commentID=1178390#comment-1178390
Hope can do help for you.
Rita_Wang
I will confirm it for you
