Dear Sirs,
In order to run the examples of JN-AN-1201, I planned to build CIE (Coorinator) and WD (Device).
Step 1. Build CIE and download to JN5169 USB dongle.
Step 2. Build WD and download to JN5169 DR1174 + DR1175.
After power on the two parts, I just see the print message from COM port attached to WD.
The messages show that the WD device can not join to CIE (Coordinator).
How to let WD join to CIE normally?
Thanks.
Solved! Go to Solution.
Hi Alan,
Unfortunately, the example doesn't have implemented the USB with the CIE device.
For a better reference please look at the JN-AN-1201 Documentation.
The LCD Expansion Board (DR1215) is used as the display panel for the system’s Controlling and Indicating Equipment (CIE) device
You could implement by your side, and modify the LCD display to the UART port into the USB Dongle.
Sorry for any inconvenience that this may cause you.
Mario
Hi Alan,
Mario
