I am trying to build the imx8mqevk BSP using the meta-freescale layer from the yocto zeus branch. There is a machine configuration for this target in meta-freescale/conf/machine/imx8mqevk.conf, but using this file results in a compilation error when building the linux-imx_5.4 kernel recipe:
| make[2]: *** No rule to make target 'arch/arm64/boot/dts/freescale/fsl-imx8mq-evk.dtb'. Stop.
| /home/tkoeller/imx-manifest/build/tmp/work-shared/imx8mqevk-basler/kernel-source/Makefile:1243: recipe for target 'freescale/fsl-imx8mq-evk.dtb' failed
| make[1]: *** [freescale/fsl-imx8mq-evk.dtb] Error 2
| /home/tkoeller/imx-manifest/build/tmp/work-shared/imx8mqevk-basler/kernel-source/Makefile:179: recipe for target 'sub-make' failed
| make: *** [sub-make] Error 2
This is because the file name 'fsl-imx8mq-evk.dtb' is wrong, it should be 'imx8mq-evk.dtb', without the 'fsl-' prefix. The machine configuration files in the new meta-imx layer correctly reflect the device tree name changes, unfortunatly, there is no machine configuration for imx8mqevk in this layer.
Hello Thomas Koeller,
Would you please confirm which BSP you are using? Are you using one of the BSP Releases or the Community BSP?
I would recommend using the BSP Release L5.4.3_1.0.0 if possible (which is based in Zeus).
Thank you - I will try that.
regards,
Thomas
Thomas Koeller
Senior Software Developer
<https://www.baslerweb.com/?utm_medium=email&utm_source=basler-internal&utm_content=basler%20logo>
Basler AG
An der Strusbek 60-62
22926 Ahrensburg
Germany
Tel. +49 4102 463 390
Fax +49 4102 463 46 390
Thomas.Koeller@baslerweb.com
<http://www.baslerweb.com>www.baslerweb.com<http://www.baslerweb.com>
<http://www.facebook.com/BaslerAG> <https://twitter.com/Basler_AG> <https://www.linkedin.com/company/basler-ag> <http://www.kununu.com/de/all/de/it/basler> <http://www.youtube.com/user/BaslerAG> <https://www.xing.com/companies/baslerag> -[https://www.baslerweb.com/baslermedia/socialmediaicons_email_signature/imaginghub_blue.gif]<https://imaginghub.com/partners/category-hardware/51-basler-ag>
Vorstand: Dr.-Ing. Dietmar Ley (Vorsitzender) · John P. Jennings · Arndt Bake · Hardy Mehl
Aufsichtsratsvorsitzender: Norbert Basler
Basler AG · Amtsgericht Lübeck HRB 4090 · Ust-IdNr.: DE 135 098 121 · Steuer-Nr.: 30 292 04497 · WEEE-Reg.-Nr. DE 83888045
