What is the current output of the servo-rail in the FMU?
iaingalloway
iaingalloway
Gerald Peklar(opens in new tab):do_not_litter:  4 days ago
Depends on the BEC you are connecting to the servo rail. If you like to run servo's you need to connect a BEC/5V supply to the servo rail input. The FMUK66 is not supplying power to the servo-rail.
iaingalloway
