Gerry Kurz
MCUxPresso Export Bug
Discussion created by Gerry Kurz on May 5, 2020
Latest reply on May 11, 2020 by Tonda Tomanec
I have discovered that the export function does not match the current routed pins window. It seems once a pin has been routed and labeled, even if it is unrouted and/or relabeled, the original data shows up in the csv file instead of the current data.
Has any one seen this? Is there a workaround?
Routed pins window
csv export of routed pins
