LPI2C Receive error
Question asked by Vasudhevan G on May 5, 2020
Latest reply on Jun 10, 2020 by Vasudhevan G
Hii,
     Board = IMXRT1064 evk
     PCF8563 rtc module interfaced with LPI2C1 master.
     Whenever i am trying to read using LPI2C_MasterReceive call returning 999.
     Code :
    #define LPI2C_MASTER_SLAVE_ADDR_7BIT 0xA2U
    #define LPI2C_MASTER_SLAVE_ADDR_READ 0xA3U
    #define LPI2C_BAUDRATE 100000U
    uint8_t deviceAddress = 0x02U;
    uint8_t recv_data;
    LPI2C_MasterGetDefaultConfig(&masterConfig);
    /* Change the default baudrate configuration */
    masterConfig.baudRate_Hz = LPI2C_BAUDRATE;
    /* Initialize the LPI2C master peripheral */
    LPI2C_MasterInit(EXAMPLE_I2C_MASTER, &masterConfig, LPI2C_MASTER_CLOCK_FREQUENCY);
/* Send master blocking data to slave */
    if (kStatus_Success == LPI2C_MasterStart(EXAMPLE_I2C_MASTER, LPI2C_MASTER_SLAVE_ADDR_7BIT, kLPI2C_Write))
        /* Check master tx FIFO empty or not */
        LPI2C_MasterGetFifoCounts(EXAMPLE_I2C_MASTER, NULL, &txCount);
        while (txCount)
        /* Check communicate with slave successful or not */
        if (LPI2C_MasterGetStatusFlags(EXAMPLE_I2C_MASTER) & kLPI2C_MasterNackDetectFlag)
            return kStatus_LPI2C_Nak;
        reVal = LPI2C_MasterSend(EXAMPLE_I2C_MASTER, &deviceAddress, 1);
        if (reVal != kStatus_Success)
            return -1;
        reVal = LPI2C_MasterRepeatedStart(EXAMPLE_I2C_MASTER, LPI2C_MASTER_SLAVE_ADDR_READ, kLPI2C_Read);
            return -1;
        while (txCount)
        reVal = LPI2C_MasterReceive(EXAMPLE_I2C_MASTER, &recv_data, 1);
            return -1;
        reVal = LPI2C_MasterStop(EXAMPLE_I2C_MASTER);
            return -1;
How to solve receive error ?
Thanks & Regards,
           Vasu
