I'm using yocto build
please provide step by step process to build the yocto project for imx6solo
Hi, team please suggest any solution.
If you change the DDR in your design you need to first configure the DDR parameters according the DDR script and then do the DDR test. https://community.nxp.com/docs/DOC-94917
