Gpio based sensor integration in lpc11xx platform
lofnakumari
I gone through the below thread and need the same code required for lpc11u6x. Is this code is working.. Can I have full code of this using this sensor.. wait function is missing.. Plz share the full source code from this thread.. https://community.nxp.com/message/782439#comment-782329
Rgds
Labels (2)
jeremyzhou
Hi Lofna Kumari ,
for the opportunity to serve you.
1) Can I have the full code of this using this sensor?
I'm afraid to find the full code, as this thread is migrated from the older community and its server already closed.
Ping
lofnakumari
please help me the logic if anyone did the same.
jeremyzhou
Hi Lofna Kumari ,
Thanks for your reply.
To implement it, first, you should understand then transmit protocol by reviewing the datasheet of the sensor, next, manipulate the GPIO implement the transmission according to the protocol.
Ping
