jn5169
jn5169
490044512
BeyondStudio for NXP更新插件出问题:
An error occurred while collecting items to be installed
session context was:(profile=profile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,com.jennic.OSConfigDiagramEditor,1.2.3
No repository found containing: osgi.bundle,com.jennic.OSConfigDiagramEditor.diagram,1.2.3
No repository found containing: osgi.bundle,com.jennic.OSConfigDiagramEditor.edit,1.2.3
No repository found containing: org.eclipse.update.feature,com.jennic.sdk.rtos.external.feature,1.2.3
No repository found containing: org.eclipse.update.feature,com.jennic.sdk.zbpro.external.feature,2.0.0
No repository found containing: osgi.bundle,com.jennic.zps.configeditor,2.0.0
No repository found containing: osgi.bundle,com.jennic.zps.configeditor.edit,2.0.0
No repository found containing: osgi.bundle,com.jennic.zps.configeditor.editor,2.0.0
1979717461
你好,我也出现了这样的问题,你解决了吗?
mario_castaneda
What is the process that you are following? What is the SDK that you are installing?
What is the application note that you are trying to run?
Mario
490044512
The development environment for jn5169 module installation prompts the above error, and no matter how to install the software, it cannot be solved. The SDK package of jn5169 module will be reported as the above error by BeyondStudio for NXP software installation
mario_castaneda
Please look a the next document
https://community.nxp.com/docs/DOC-340028
Mario
490044512
  • There is no solution to this problem
mario_castaneda
Could you please provide a screen of your issue?
What is the SDK that you are working on?
What is the AN that you are trying to run?
Mario
490044512
The SDK used is jn-sw-4170 Zigbee 3.0 v1840. The AN to run is jn-an-1216
mario_castaneda
I am assuming that you are trying to install the plugin, Am I wrong?
If you are installing this, please download the JN-SW-4168 SW and follow the same steps using this SDK.
Could you please provide the document that you are following?
Mario
490044512
The problems mentioned above still occurred when installing the plug-in in the SDK of jn-sw-4168 which was replaced。
Is it because I live in China and your company's server is in a foreign country that I cannot download the plug-in due to network problems
mario_castaneda
I think you do not have any problem with the server for this plugin.
Is it possible that you could uninstall Beyond Studio and install it again? After that, install the Plug-In following the chapter
1.2.3 Installing the ZigBee Plug-ins
https://www.nxp.com/docs/en/user-guide/JN-UG-3098.pdf
Mario
1979717461
Uninstalling and reinstalling again will not solve this problem. I also have this problem. It seems that there is no such situation before 2020.
490044512
Yes, I was installing plug-ins, but I have reinstalled the software for several times. The SDK is jn-sw-4170 Zigbee 3.0 v1840捕获3.PNG
