Hello there,I'm writing an application on Raspberry 4b using Raspbian Weezy and Qt5.
I need NFC reading so I bought a EXPLORE-NFC-WW but... I'm a newbie about it, I don't understand how configure IT
I've see some videos but, for example, the Raspberry 4 doesn't have the SPI kernel module option.
There is any "for dummies" guide to try this board and include the needed libraries in my c++ software?
I didn't found any information about this specific board onto this specific raspberry model.
I hope you can give me some help
thanks a lot
regards
Michele
This is the web page of EXPLORE-NFC
EXPLORE-NFC - Exclusive from element14 | NXP
You can download the quick start guide and library from this web page.
Thanks for your reply.
I saw that documentation, I could compile and run explorenfc-basic software to read NFC devices.
My problem is how integrate that library in a c++ project (.pro file LIBS configuration parameters)
Have you got any example? Into Source library there are any example, but I don't understand how use int into c++ project, which library links etc.
thanks a lot for your time
Michele
Hi Michele,
I'm interested to know whether you succeeded with your project?
Did you find any help from this blog or NXP?
Willem
