S32K144EVB OpenSda Debugger
nieqi
Hi:
   I modified the opensda debugger pin by accident.I can't debug the S32K144EVB now, how do i erase the s32k144 chip .so i can recover the S32K144EVB.
 As you see, i use the S32Designed Stdio to develop the software.How can i do nex step。
I think the Port Module of AUTOSAR MCAL modify the pin configuraion as Pin diable Mode(Alternative).So i can't debug.
Robin_Shen
Hi Archie,
Have you check your source codes, if below debug pins are disabled by your software?
JTAG_TMS/SWD_DIO_PTA4
JTAG_TCLK/SWD_CLK
Have you try to select Emergency Kinetis Device Recovery by Full Chip Erase in debug configurations?
If still not work, please try to refer the P&E Recovery Utility described in "Bricking and Recovering FRDM-KL25Z Boards: Reset, SWD Clock and Low Power".
Robin
nieqi
Hi Robin:
   I'm so sorry.I recover my board Now! Thank you very very very very much!
Robin_Shen
You are welcome!
I am glad to hear that it works now.
nieqi
Hi Robin:
   Thanks for you reply.
I try to select Emergency Kinetis Device Recovery by Full Chip Erase in debug configurations.It's not available. It's report a connetion error
My Borad Configuration is default state.
  I Read the Bricking and ercovering exsample.So I follow the exsample step by step.It's not working.My Recover Utility Can'nt choose SWD or JTAG.
Is any other way recover my S32K144EVB.
Tks,Best Regards.
