How many ways can you start an M4 processor on an IMX8MM chip?
bigtruck
On IMX8MM chips, it is now known that the M4 processor can be started from uboot using the bootaux command.Can I still boot the M4 processor with Linux?How to do that?
Tags (2)
karangajjar
Senior Contributor II
Hi 勇 肖,
Yes, as you have found u can boot M4 from u-boot. There is generally no way to boot M4 image from Linux.
Karan Gajjar
