gstreamer rtsp server on "i.MX 8M Mni EVK"
ysato_ad
I want to implement gstreamer rtsp server on "i.MX 8M Mini EVK".
https://www.nxp.com/docs/en/user-guide/IMXLXYOCTOUG.pdf
I set up Yocto Project on the host machine while referring to the above.
Then, at https://www.nxp.com/docs/en/user-guide/IMXLUG.pdf
I did bitbake with reference to '7.3.14 RTSP streaming server',
But, there are no .libs, no builds directory.
Please tell me the cause and measures.
For the time being, I checked the following, but it did not work.
https://community.nxp.com/thread/380070
What I did:
1) $ cd imx-yocto-bsp
2) $ MACHINE=imx8mmevk DISTRO=fsl-imx-xwayland source ./fsl-setup-release.sh -b build
3) $ gedit ./conf/bblayers.conf &
LCONF_VERSION = "7"
BBPATH = "${TOPDIR}"
BSPDIR := "${@os.path.abspath(os.path.dirname(d.getVar('FILE', True)) + '/../..')}"
BBFILES ?= ""
BBLAYERS = " \
${BSPDIR}/sources/poky/meta \
${BSPDIR}/sources/poky/meta-poky \
${BSPDIR}/sources/meta-openembedded/meta-oe \
${BSPDIR}/sources/meta-openembedded/meta-multimedia \
${BSPDIR}/sources/meta-freescale \
${BSPDIR}/sources/meta-freescale-3rdparty \
${BSPDIR}/sources/meta-freescale-distro \
# i.MX Yocto Project Release layers
BBLAYERS += " ${BSPDIR}/sources/meta-fsl-bsp-release/imx/meta-bsp "
BBLAYERS += " ${BSPDIR}/sources/meta-fsl-bsp-release/imx/meta-sdk "
BBLAYERS += " ${BSPDIR}/sources/meta-browser "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-gnome "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-networking "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-python "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-filesystems "
BBLAYERS += " ${BSPDIR}/sources/meta-qt5 "
BBLAYERS += " ${BSPDIR}/sources/meta-openembedded/meta-multimedia " #add
4) $ gedit ./conf/local.conf
MACHINE ??= 'imx8mmevk'
DISTRO ?= 'fsl-imx-xwayland'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES ?= "debug-tweaks"
USER_CLASSES ?= "buildstats image-mklibs image-prelink"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS ??= "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
STOPTASKS,/tmp,100M,100K \
ABORT,${TMPDIR},100M,1K \
ABORT,${DL_DIR},100M,1K \
ABORT,${SSTATE_DIR},100M,1K \
ABORT,/tmp,10M,1K"
PACKAGECONFIG_append_pn-qemu-native = " sdl"
PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
CONF_VERSION = "1"
DL_DIR ?= "${BSPDIR}/downloads/"
ACCEPT_FSL_EULA = "1"
IMAGE_INSTALL_append += "gstreamer1.0-rtsp-server" #add
5) $ bitbake core-image-minimal
6) $ cd ~/imx-yocto-bsp/build/tmp/work/aarch64-poky-linux/gstreamer1.0-rtsp-server/1.14.4-r0
7) $ ls -la
drwxrwxr-x 12 sato sato 4096 4月 11 11:46 .
drwxrwxr-x 3 sato sato 4096 4月 11 11:45 ..
drwxr-xr-x 3 sato sato 4096 4月 11 11:35 deploy-rpms
drwxrwxr-x 3 sato sato 4096 4月 11 11:34 license-destdir
drwxr-xr-x 6 sato sato 4096 4月 11 11:34 pkgdata
drwxrwxr-x 2 sato sato 4096 4月 11 11:45 sstate-install-package_qa
drwxrwxr-x 2 sato sato 4096 4月 11 11:46 sstate-install-package_write_rpm
drwxrwxr-x 2 sato sato 4096 4月 11 11:46 sstate-install-packagedata
drwxrwxr-x 2 sato sato 4096 4月 11 11:46 sstate-install-populate_lic
drwxrwxr-x 2 sato sato 4096 4月 11 11:45 sstate-install-populate_sysroot
drwxr-xr-x 4 sato sato 4096 4月 11 11:34 sysroot-destdir
drwxrwxr-x 2 sato sato 4096 4月 11 11:46 temp
radhikasomaiya
Senior Contributor II
Hi ysato.ad@minebeamitsumi.com ,
To build .libs/test-uri (to build examples and tests) remove or comment the below line from file gstreamer1.0-rtsp-server.inc (path: sources/poky/meta/recipes-multimedia/gstreamer/gstreamer1.0-rtsp-server.inc).
         EXTRA_OECONF = "--disable-examples --disable-tests"
then follow the steps from section 7.3.14 RTSP streaming server of i.MX Linux User's guide.
Let us know if you have any further query.
Radhika Somaiya.
radhikasomaiya
Radhika Somaiya.
ysato_ad
Hi Radhika Somaiya
Thank you for your reply.
Before seeing this reply, I tried the following and was able to confirm the operation.
But I was wondering why bitbake doesn't automatically make it.
I understand from your reply.
I tried the method you taught me.
It was automatically made with bitbake.
Thank you very much.
8) $ bitbake -c cleanall gstreamer1.0-rtsp-server
9) $ bitbake gstreamer1.0-rtsp-server
10) $ cd ~/imx-yocto-bsp/tmp/work/aarch64-poky-linux/gstreamer1.0-rtsp-server/1.14.4-r0/build/examples
11) $ls -la
   drwxr-xr-x 2 sato sato  4096  4月  12 13:10 .
   drwxr-xr-x 9 sato sato  4096  4月  12 13:10 ..
   -rw-r--r-- 1 sato sato 47297  4月  12 13:10 Makefile
11) $ make
   ....snip....
   make: aarch64-poky-linux-gcc: Command not found
   Makefile:736: Failed in recipe for target 'test-video.o'.
   make: *** [test-video.o] Error 127
12) $ source /opt/fsl-imx-xwayland/4.14-sumo/environment-setup-aarch64-poky-linux
   (*)I have done the following in advance:
     $ bitbake -c populate_sdk core-image-minimal
     $ cd ~/imx-yocto-bsp/tmp/deploy/sdk/
     $ /fsl-imx-xwayland-glibc-x86_64-core-image-minimal-aarch64-toolchain-4.14-sumo.sh
13) $ export ARCH=arm64
14) $ make
15) $ ls -la
   drwxr-xr-x 3 sato sato  4096  4月 18 16:45 .
   drwxr-xr-x 9 sato sato  4096  4月 18 15:38 ..
   drwxrwxr-x 2 sato sato  4096  4月 18 16:45 .libs
   -rw-r--r-- 1 sato sato 47297  4月 18 15:38 Makefile
   ----- snip -----
   -rwxrwxr-x 1 sato sato 11245  4月 18 16:45 test-launch
   ----- snip -----
   -rwxrwxr-x 1 sato sato 11212  4月 18 16:45 test-uri
   ----- snip -----
16) Copy the contents of'.libs' to the target / usr / lib / using SCP
17) Copy sample MP4 (aaa.MP4) to / home / root / using SCP
18) test-uri file:///home/root/aaa.mp4
  --> Host PC VLC application : rtsp://(target ip address):8554/test
  --> MP4 Streeming Play OK.
19) test-launch '( v4l2src device=/dev/video0 ! videoconvert ! vpuenc_h264 ! rtph264pay name=pay0 pt=96 )'
  --> MIPI CSI CAMERA Streeming Play OK.
joanxie
you can use this L4.14.98-2.0.0_ga, but core-image-minimal is the minimal image which only supports board booting up, try to use "fsl-image-qt5-validation-imx"
ysato_ad
Hi Joan Xie
I have verified that test-uri can be run on the target of L4.14.78_1.0.0_MX8MM.
Is L4.14.78_1.0.0_MX8MM that can be downloaded from the following URL bit-baked with "fsl-image-qt5-validation-imx"?
https://www.nxp.com/webapp/sps/download/license.jsp?colCode=L4.14.78_1.0.0_MX8MM&appType=file1&DOWNL...
joanxie
yes, it should be built by "fsl-image-qt5-validation-imx", but since you need add your own feature in the bb file, I think you should build by yourself
ysato_ad
Hi Joan Xie
I was checking RTSP in the environment of 'L4.14.78_1.0.0_MX8MM' I wrote first.
I checked the writing of the image of 'core-image-minimal' that I created, and it was CUI.
Recreate the image with 'fsl-image-qt5-validation-imx'.
Thank you.
radhikasomaiya
As per the Yocto project User's guide, L4.9.88_2.0.0_ga is not supported for imx8mmevk so, Have you added the support of i.MX8M mini in rocko by yourself?
We are working on it with sumo L4.14.98_2.0.0.
Radhika Somaiya.
ysato_ad
Hi Radhika Somaiya
Sorry.
I forgot to write my current environment.
https://source.codeaurora.org/external/imx/imx-manifest/tree/?h=imx-linux-sumo
I referred to the following URL and used 4.9.88-2.3.1.
> $ mkdir imx-yocto-bsp
> $ cd imx-yocto-bsp
> $ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.9.88-2.3.1.xml
> $ repo sync
