SDK_S32K1xx_15 adc_pal 配置ADC1,调用初始化函数ADC_Init不通过
我用PE配置ADC1采样,工程添加了ADC_PAL组件,初始化调用了生成的接口函数ADC_Init(&adc1_pal_instance, &adc1_pal_InitConfig0);debug程序死在了这里。我该如何解决?
Hi ruide xin,
As the software suggests, you should uncheck the "Extension Supply Monitoring Enable".
Robin
