JCOP 3 Tool install for eclipse problems
Question asked by Tony Sims on Apr 7, 2020
Latest reply on Apr 21, 2020 by Kan_Li
I'm having trouble with the accessing the JCOP 3 licensing wizard to activate our JCOP tools. The wizard doesn't show if I try to create a new project. I have the Oracle JCDK 3.1 installed and it also uses a Java Card Project wizard. But I have to assume that the JCOP tools use a separate wizard. At any rate, there isn't a separate folder showing for the JCOP tools. Can you assist in getting this corrected. The version of eclipse that I am using is 4.8.
Tony
