S32K146 Application layer codes stop at DefaultISR:
609510318
When I debugger the S32K146 board,my application layer codes stop at  “b DefaultISR” after running for a while.How can I solve this problem?What is the reason?Thanks.
DefaultISR:
b DefaultISR
.size DefaultISR, . - DefaultISR
dianabatrlova
Could you, please, specify the line/ function after which triggers DefaultISR (when you debug the code)?
One of the reasons could be that you do not configure the clock for some peripherals.
Diana
