SC18IS602B Chip Select Function
Question asked by Shreya S on Apr 7, 2020
Latest reply on Apr 22, 2020 by Shreya S
I want to interface SC18IS602B with DAC AD5504. For this Chip Select has to toggle(low to high) after 16bits of data is transmitted. What is the behavior of Chip Select pin on SC18IS602B? Will it toggle from low to high after each data byte is transmitted or after all data bytes in the buffer (up to 200 bytes) are transmitted? There is no timing diagram given in the data sheet.
Thanks in advance.
