hi ,请问下,数据手册中有如下描述,这个意思是不是我外面接的对地电阻或者是等效电阻不能大于5K欧姆?
Hi haifeng.jin,
There is application note which gives a thorough description of internal/external impedance matching:
AN4373 Cookbook for SAR ADC Measurements ADC measurements done properly
https://www.nxp.com/docs/en/application-note/AN4373.pdf
AN12217 S32K1xx ADC guidelines, spec and configuration
Analog-signal source resistance
https://www.nxp.com/docs/en/application-note/AN12217.pdf
