Software breakdown on interrupt?
Question asked by Matthias Harms on Apr 1, 2020
Latest reply on Apr 10, 2020 by Alexis Andalon
I´m new with the Kinetis Controllers and I get a problem with the Interrups.
I´m using the IAR Workbenck and a Jlink programmer.
If I put my software on an MKL03Z8VFG4 every time a interrupt is triggert the controller jumps to an not used flash adress.
I have check with the TMP0, TMP1, LPTMP0 and the ADC interrupt.
If the interrupt is not triggert the programm work fine.
The same Software on the FRDM-KL03Z Board have no problems.
I check the map file and see the IQR Handler on the correct position.
Have somebody an idea about this problme?
