Hi Chen Xiao,
Can you let me know where your code is getting stuck? Usually, one of the reasons for this problem is the stack size gives it for the tasks, it can be modified in the following section:
And also, increasing the heap size usually helps too.
Let me know if this helps you.
Alexis Andalon
that's ok ,thanks!
