Arda Otuz
MCUXpresso Config Tools V7.0 -- WDTT Configuration Bug
Discussion created by Arda Otuz on Mar 27, 2020
Latest reply on Apr 17, 2020 by Diego Charles
Using LPC802M001JDH20
As configuring the WDTT, even though everything (including clocksource and frequency) in Config Tools software is specified;
Config Tools provides the following inside peripherals.c:
const wwdt_config_t WWDT_config = {
.enableWwdt = true,
.enableWatchdogProtect = false,
.enableLockOscillator = true,
However, system fails inside fsl.wwdt.c -> WWDT_Init function @line 139 "assert(0U != config->clockFreq_Hz);"
Reason: Config Tool must add clock frequency inside WWDT_config struct:
.enableWwdt = true,
.clockFreq_Hz = XXXXXXX                <- should be added but not by the Config Tools
Unless you fix this section by adding clockFreq manually, code will fail @ assert(0U != config->clockFreq_Hz);
